loaded InputType () not supported error
When using 2 DSI-LVDT modules with a dewe-43A I get the attached error message. I have created a new setup file, with just the 2 LVDT modules connected (detected via TEDS) saved the setup file and reopened the setup file and this warning message presents every time. Is there a fix for this?
Thanks
@Tristan Jones
thank you for contacting us. We have successfully reproduced your issue. Luckily the measurement data should be OK and it is merely a visual issue. We will inform our software development team who will look at the problem.
If you should have any further issues feel free to contact us.
Kind regards,
Vitjan Lin Zupan
Customer support
We would like to inform you that the issue "Loaded input type not supported warning when connecting DSI-LVDT adapter to DEWE-43-A or SIRIUS" was solved in the new DewesoftX version 2024/1/RELEASE-240220.
Best regards
