Installation of two versions of Dewesoft X3
  • Installation of two versions of Dewesoft X3
Benji N
Posted on 22.01.2020 13:26
Hi!
Is it possible to install for exempel X3 SP5 32-bit if you already have X3 SP8 64-bit?
Rok Kmetič
Posted on 22.01.2020 15:05
Dear Benji,
it is possible to install different versions of Dewesoft, you can install the official release (32bit and 64 bit), the release candidate (32bit and 64 bit) and the development version (32bit and 64 bit). These are 6 different installations.
We didn't test it but you can try to install different softwares, there will be no problems, just make sure that the different SP versions are installed in separate folders.
I hope the above works for you.
Kind regards.
Rok Kmetič
Benji N
Posted on 27.01.2020 10:10
Thanks Rok!
That may explane my problem.
I did not choose different folder when I installed it. I thought it would automatically choose another folder since I had a folder called Dewesoft, but did not. I got both of them in same folder and I could not start the 32bit version.
