Input Control bug: [Dewesoft action, Filename, Filename only] showing full path, not filename only regardless of selection.
  • Input Control bug: [Dewesoft action, Filename, Filename only] showing full path, not filename only regardless of selection.
Lemmy Atom
Posted on 25.05.2021 19:11
Version: 2021.2 (RELEASE-210430) (64-bit)
As the title says, regardless whether Filename only or Folder and filename are selected from the dropdown, the input control widget shows folder and filename I.E full path.
I think this is a bug in the newer release? I used to be able to control this function. Now I can't.
Matic Pevec
Posted on 26.05.2021 07:44
Dear Lemmy,
Thank you for noticing this. This issue was already fixed in version 2021.3 - RC that is available on the webapge. Official release of this will be next month.
BR
