Input audio files (like .wav)
Vladimir Zaitcev
Posted on 10.02.2023 19:27
Hi!
Sorry for my bad English)
What format are the audio files and how can I use them to play them through SIRIUS to speakers, as it happens for example with a sine signal?
Primoz Lapi
Posted on 13.02.2023 16:49
if I understand correctly, you would like to play the signal recorded with Sirius on speakers?
You can export the signal to *.wav file:
You can also play the signal directly from Dewesoft:
Vladimir Zaitcev
Posted on 13.02.2023 18:50
Thanks, but not quite that. I would like to import ".wav" (or other audio file format) in Sirius and play it on the speakers.
Primoz Lapi
Posted on 14.02.2023 10:02
we don't support *.wav file import, but you can convert it to txt and then import it to Dewesoft.
Maybe something like this for converting the file: https://anyconv.com/wav-to-txt-converter/
You can then output it on Sirius analog output.
signup
for
free
account
