Increment a Counter Bit based on threshold criteria
  • Increment a Counter Bit based on threshold criteria
Xander Goldstein
Posted on 28.09.2021 21:15
I am trying to use my IOLITE to monitor voltage from a battery pack, I have it set to an IOLITE-LV analog input and have the nominal +6V recording on the monitor. What I'm trying to achieve is that I need to count how many times during the test the voltage drops below a defined value. What would be the best way to calculate this and display the "count" number? Thank you.
Gregor Šmit
Posted on 30.09.2021 12:57
Dear Xander,
thank you for contacting us. In the attachment is a data file with an example. Formula to count the number of times the signal is below 0.5:
ecnt(edge('signal'<0.5)
When a signal is below 0.5 the edge function returns 1 and the ecnt function counts the edges. In the attached example a sine wave is used and the predefined value is 0. The counter value is displayed on a digital meter.
Kind regards.
Xander Goldstein
Posted on 30.09.2021 15:46
@Gregor Šmit
Thank you! that will definitely get me in the right direction.
