Increase resolution on Recorder Chart
Below you can see two charts of the same data, just changing a little bit the zoom. The aproximation from dewesoft to increase performance is too far from reality and I'd like to know if there is any parameter in the dewesoft x3 configuration to limit these aproximations and see the recorded data in a more accurated way.
Could the problem come from importing with Async and so dewesoft is trying to "guess" the data?
Dear Raul,
could you provide the data file with the signal, so we can look into this?
Regards
@DEWESoft Support
Attached you will find it.
we have the same issue: when CAN Signals are changing rapidly in Dewesoft recorder the display is washed out.
Dear Raul,
if you increase the async DB buffer length in the settings/performance, the performance of the data will be better.
Regards
