In Sequencer Comment WIndow
I am currently working on creating a sequencer that runs through the basic steps to create a DeweSoft X3 setup that helps people with less experience easily create a test setup for our lab. I was wondering if there is any way to add text windows to guide them through the sequencer; other than just the title of the Wait block.
Thank you.
Software Test Engineer I
The sequencer in X3 has a comment block which you could use.
I have tried using the comment block but I can't seem to figure out how to have it stick around. Whenever I run the sequencer it quickly skips any comment blocks within it. How do I get the block to run and stay on the screen?
Sorry, we misunderstood each other. Unfortunately there isn't a way to display a large comment while the sequence is running right now.
I can however add a feature request to our developers, for the comment block to display the message in a popup window.
