GPS Position format
We frequently need to transfer GPS positions from Dewesoft recordings into Google maps.
Is there a simple way to take the GPS coordinates, as shown in my example here, and convert them to a format that can be simply copied and pasted into Google Maps?
Currently we must manually transpose the information and type it into Google.
Dear Phil,
you can export GPS coordinates into *.kml format. The *.kml format can then be imported into the Google maps (My maps). You can see the instructions on the following link.
Regards
Dear Phil,
Regards
Thank you - I realise that this is possible but it does not allow me to pinpoint events in the data.
For example, within Dewesoft I analyse the data from our sensors to find an event. I then need to take the GPS position of that event and locate it within Google Maps. If I simply export the entire Route I do not know where on the journey the event occured.
Dear Phil,
would it be possible that you share an example data file of those events, so we can look into the data?
We would like to know how are the events defined? Can they be "changed" into formula?
Eva
