GOTO Value
- I have looked high and low and cannot find a simple way to have cursor go to a specified Y value in analysis mode. Can anyone help?
I believe that the same "Go-To" feature was requested by one of your colleagues not too long ago. Dewesoft doesn't really have a dedicated function for this, but I've put together a demo setup which can be used to in order to get as close as possible to simulating this function. Below you'll find my response to that request and I've attached the setup file and some pictures that were referenced in my reply. I haven't heard back from your colleague on this, but I hope you'll find this math useful.
"In the attached setup I've tried to simulate your original request. I have three DEMO channels, a sine, square and trian wave and am looking at where the sine wave signal crosses the zero threshold (positive edge). This can be done directly through the "Latch value math" setup. If you'd like to use a different triggering logic, then it would be a bit more complicated, but still doable.
As you can see on the image above, the criteria channel is the sine wave, while the latch function will return data from all three channels. I've used a "Tabular" values display to show the latched values and the recorder to show all of the original signals. In analysis, you can double click on any sample in the tabular values display, which will automatically move the yellow cursor to the correct destination. You can use the double click feature as sort of a "jump to next" functionality.
The only slight inconvenience that I've noticed in my testing was that sometimes the sample which you click on doesn't color yellow as expected. The reason for this is that the double click feature will move the yellow cursor to the nearest synchronous sample. Sometimes, the latched sample is just a bit delayed compared to the synchronous sample. As the tabular display will color the closest previous sample to the cursor, this means that the previous sample will still be colored. I've already shown this to the development team and they'll see what can be done to make the adjustment."
So far so good for the positive edge, what about for the negative edge? We normally would locate where the triangle or sine wave crosses zero for both rising and falling signals.
I've made some adjustments to the setup. The change I've made is that the triggering condition is now a separate math channel. In that channel, I output a 1 whenever the sine wave crosses over zero (either positive or negative edge), and stays at 0 at all other times. In the latch math, I then use this channel as the latch condition.
@DEWESoft Support
Hi there, I have been using this method successfully but seem to have stumbled across an issue. When you have the 'reverse value display' the double click to jump feature falls over and some times works but the majority of the time will not. Is there a reason for this?
Dear Alan,
Thank you for noticing the issue. We could reproduce this on our side. We have transferred the issue to the software development team for further analysation.
Best regards
@Alan Mobbs
Dear Alan,
we would like to inform you that the issue has been fixed in the software release candidate version 2023.5 RC-230807.
Best regards
