Flat under curve
I would like to ask you if is possible to count flat under measured curve with using any math function or equation or is it necesarry to export it and count in Matlab for example.
Thank you for any help :)
Dear Jan,
to count the flat under measured curve you can create a c++ code in our c++ script.
Regards
Thank you for your help, but I do it in correspond with your manual for "Using different methods to calculate work..." (https://download.dewesoft.com/download-file/integration-math-methodszip). But I one another problem. When I am zoomed any area of measurement the counted vaues aren't be recalculated only for this region. Is any possibilities how to do this, please? In example with Order tracking function is here Offline calculating, but I am not able to use it with equations. Thank you.
Dear Jan,
if you put the channel to Offline mode,then it will automatically be set to offline when you zoom into chosen area.
Regards
Thank you. I would like to do that as normally, but I am not able to set shich choice in channel properties as it shown on attached picture. BTW I am using DeweSoft X3 SP6 (RC-181231) (64-bit)
Dear Jan,
you have to right click on the description bar (first row) and click "edit columns"
than you can add the offline column to display.
Regards
Great!
Thanks a lot! Everything works well right now!
Have a nice day!
