File Overlap With "Fast on Trigger Slow Otherwise" and "Make New File After" each 1 Trigger and Pre/Post Trigger Time
  • File Overlap With "Fast on Trigger Slow Otherwise" and "Make New File After" each 1 Trigger and Pre/Post Trigger Time
Matt Hanks
Posted on 03.12.2019 16:52
I'm using the "Fast on Trigger Slow Otherwise" data recording mode with the "Make New File After" option enabled. The new file is made after each 1 Trigger.
I also have pre and post trigger times assigned.
There is slow data stored after the triggered fast data that overlaps with the slow data at the start of the next file. Can someone explain the logic that is occurring? I have tested this in both X3 SP7 and X3 SP9 and it seems to function the same.
Matic Pevec
Posted on 23.12.2019 14:23
Dear Matt,
Dewesoft store data in blocks. Block size is defined by "reduced rate". One block can contain more than one trigger. Additionaly, start event of second trigger can be in the same block as stop event of first trigger. Therefore this block exists in two files which overlap.
Best regards
Matic Pevec
