Feature update. Duty cycle control
Using the function generator and Sirius module. The ability to adjust the duty cycle would be a great feature. Currently running a square wave. I can adjust frequency. P to p. But it runs only 50% dc. I need to adjust from 0 to 100
Support Tech Manager
Peter,
While the Function Generator in DEWESoft does not have a section that explicitly says "Change the duty cycle to ___%" there is a way to get this functionality using Math and then assigning a certain pulsewidth modulation to a function generator signal and make it adjustable to the user. In fact there is actually a video available on youtube that explains this functionality so you are able to follow along and replicate it. You can find that video here https://www.youtube.com/watch?v=Rv5brc4CVhE and a setup showing that example is available as an attachment to this post. This should get you the functionality you are looking for!
- Corey Schwanz
- DEWESoft US Support
