Exporting to FlexPro
I am trying to export data to FlexPro 10 from XP2 SP5. The export works fine, but then in the data signals, the Xlabels do not contain any time information but rather just numbered sequentially (1,2,3,4,...). I've tried changing all the time export options in Dewesoft (absolute/relative time) but still same result. The export works fine to MS Excel where I get the correct time. Am I missing something here?
I've tested the FlexPro export and I can see your problem. It seems to be related to the latest version of FlexPro. When I export a file to FlexPro 10.0.10, the X label will correctly contain the time of each data point. If I however export the same file while using FlexPro 10.0.13 or later, the time is missing and the X data is, as you've mentioned, only numbered sequentially. Could you please confirm that you're using one of these newer FlexPro versions? If that's the case, then you can either downgrade to version 10.010 or try contacting the FlexPro support/developers.
Yes I am indeed using 10.0.15. Am only using an evaluation license at the moment to check out FlexPro's features.
