Export to FlexPro
User Question
Posted on 03.08.2015 10:37
How to export to Flexpro from Dewesoft if Flexpro is not installed on the system?
Posted on 03.08.2015 12:48
If FlexPro is not installed, following error will appear:
To resolve this problem here are the options:
- Installation using the FlexPro setup program:
- Launch FlexPro Setup.exe
- On the Setup Type page of the installation wizard, select Custom and select the “FPAccess Interface” only.
2. Manual installation:
- Copy the files FPAccess.dll, FPAccessResources.dll and FPProxyStub.dll from the FlexPro installation folder to DEWESoft bin folder.
- Create subfolder called ENU under this folder and then move the file FPAccessResources.dll to it.
- Run the following two command lines under Start | Run in the order specified:
- regsvr32[path]\FPAccess.dll
- regsvr32[path]\FPProxyStub.dll
Example:
regsvr32 C:\DEWESoft\Bin\X2\FPAccess.dll
regsvr32 C:\DEWESoft\Bin\X2\FPProxyStub.dll
signup
for
free
account
