Export data to Uniplot
I am looking for a way to export vibration data from DEWESoft X3 SP4, to be able to plot in Uniplot.
I have tried various file types to export, none seem to work.
I was advised to use the .mat format, however I don't have MATLAB installed on this PC so I was met with the message :
"Failed to start exporting. Make sure a 64-bit version of Matlab is installed".
Is there any way to circumvent this? Or is there another file type which data should be exported as.
Thanks in advance.
AY
Dear Alexandre,
if you wan to export the data to *.mat format, you can install a free version of Matlab Runtime and the export should work.
The .mdf files are also supported ( MDF4 export).
On the following link you will also find additional supported formats:
https://www.uniplot.de/documents/en/src/uniplot/up-importing-data.html#importing-data
Regards,
