Export channel selection
I wanted to know if there is a way to automatically choose the channels that will be exported because I have a lot in my measurement file and I will not be the only one who will use it. To make it easier to use, I want to make the channels in the attached screenshot already selected when the export tab is opened and all the other ones not selected. Is there a way to do this with an option I did not see yet ?
Thanks by advance,
Maxime
Dear Maxime,
Thank you for contacting us. Export properties can be set up before or after the measurement. I will describe both solutions.
Measure
In the global view of channels, you can select which type of columns are displayed. A column of the exported channels can also be added. In “Ch. setup” and “Channels”, right click on the top bar, edit columns and select “Exported”. There are also other columns available, please refer to our online manual (channel grid).
After saving the setup file all the future measurements will have these exported channels selected.
Analyze
In your files, you can define the channels to be exported in a first file and copy paste on your others files with Apply action. First, define which channels will be exported. In “Data files”, load a file, then in “Export”, you can select the channels which you want to export and save the file. Then, apply the modification to files you want to modify. Select the files which you want to apply the modification, select “Apply action”, choose your reference file and select “Export properties” to copy export properties from reference file to all of the selected files.
Selecting two files and pressing Apply action to copy Export properties.
Kind regards,
Damien.
Thanks for your quick answer and for all the details, it now works perfectly !
I indeed did not see the Cannels tab in the Channel setup part
Best regards !
Maxime
