Executing a command based on a condition (Eg If) without using sequencer
I would like to execute a command based on the result of a condition.
I am trying to achieve this by not having to run a sequencer script.
Is this possible?
Hi Dino,
with math formulas you can use If statements. For more accurate explanation I would need more information about your application.
Regards,
Eva
Thanks for getting back.
For eg: if('x'=0) then
y=2 (or any statement)
else
y=3 (or any statement)
Dear Dino,
in Dewesoft, you can create If statements on following way: IF(condition,result1,result2).
(e.g. if('x'=0,2,3))
Regards,
Eva
Thanks for the suggestion.
However, result1 and result2 get assigned to the math channel variable that checks the condition (in this case If).
What I would like to know, is it possible to assign result1 and result2 to another variable. For eg
math_channel1=If(x=0) then y=2 else y=3
I know this is not compatible with the If syntax, but this is what I am trying to achieve. It is easy do this using sequencer, but I am looking for an alternative?
Is this possible using triggers / alarms?
Hi Dino,
unfortunately, currently this is only possible with the sequencer.
Eva
