Excitation voltage limits not working
  • Excitation voltage limits not working
Martin Chocholouš
Posted on 05.08.2025 08:37
Hi, Iam a begginer with the dewesoft software and hardware so I may be missing something.
When I create a sensor like in the first picture and set min and max excitation voltage and save (I have to click edit and save multiple times for it to start working) I can only set the excitaion voltage in the min max range as expected when the sensor is assigned to a chanel.
But the issue is, when i relload the configuration, the sensor is still assigned and the min max voltages are still in place, but i can set whatever excitation voltage i want regardless of the excitation limmits.
Is this some kind of a bug or am I missing something?
Thanks for help.
Lemmy Atom
Posted on 05.08.2025 20:04
If you want to lock your excitation at 5v, select 5 as your excitation then check the "lock all channel settings" button from the edit sensor panel. This locks the amplifier settings including the excitation.
If you want to allow a range of excitations then UNCHECK lock all channels and CHECK the sensor excitation min/max check box and give those fields a range (Min/5 Max/10 for example). This allows you to change the excitation on the amplifier side, but only within the range specified in the sensor settings.
Martin Chocholouš
Posted on 07.08.2025 06:26
@Lemmy Atom
I did what you suggested in the second paragraph and it worked until i reloaded the setup. Even tho i saved the settings for example exactly like in your second screen, i was able to set the excitation voltage to anything like 15V.
I was told that it is a bug and it has been reported.
Sam Daniel
Posted on 01.12.2025 09:33
I’ve run into similar issues with excitation limits not behaving as expected, and your notes make things much clearer. Double-checking the channel config and firmware version seems to help.
Martin Chocholouš
Posted on 01.12.2025 09:40
@Sam Daniel
I've discussed it with an employee from Dewesoft and it's a bug and ticked has allready been created so it will be hopefully fixed in upcoming versions.
Staš Jevševar
Posted on 01.12.2025 12:06
Dear all. The solution will be included in the next version 2025.3 coming this year.
The solution is also already included in the latest release candidate you can get here:
https://dewesoft.com/download/dewesoftx-development-preview
