Error while exporting
Martin Chocholouš
Posted on 23.03.2026 11:17
SOLVED
I gave it a better look and I was writing to a premade sheet and one letter was lowercase insted of upper. When the sheet name was 100% corrent it exported fine.
Hi, today a measured one set of data on Krypton 6xstg that Iam not able to export. Iam getting this error message:
Iam trying to export the data to allready populated template that I populated with data from a diferent setup. I wanted to add more data from current setup but Iam getting this error. I tried to export the data to an empty excell template and that works. Even when I try to export the data from previus setup that are allready in the file it exports just fine.
Tried restarting the dewesoftX, even the PC and no luck.
I tried searching online for this error but found no solutions.
Iam running this version of dewesoftX:
Version: 2025.3 (RC-251105) (64-bit)
Build: Release
Iam also including one of the multifiles that I have issues with as well as the setup.
Staš Jevševar
Posted on 23.03.2026 11:35
Glad to hear you've resolved this. Don't hesitate to contact us for any further questions.
