Error while calling LoadSetup function
I have used a sequencer for over six months and enhancing it in many ways. Today, after updating to 2022.2 I sometimes (!) get the following warning.
"Warning (Custom block): Error while calling LoadSetup function"
Could this be a bug coming from the update or something completely different I've made to my sequencer?
BR
Benjamin
Dear Benjamin,
thank you for reaching out to us. From the warning it seems the setup file can not be loaded. The reason could be that the path to the setup file is not correct (attached image of wrong file name where the same warning appears) or the setup file is corrupted. Would you please be so kind and check in the Custom block if the Value of the filename in the LoadSetup is correct.
Kind regards.
It does not seem to be the issue, especially since it does not happen every time the setup file is loaded. I must double check if I have something in the sequencer today that wasn't there when it worked that could have changed the setup folder (I'm excluding the folder from the filename in the LoadSetup).
BR
Benjamin
I have not checked if this is a general issue but the issue showed to only occur when going from a measurement with a start block (not storing). If I added a stop block before loadsetup, it worked fine.
