Error: Template Database not found
Hello Everyone,
in the export of the measurements data, I am trying use the advantage of the ready excel templates in the section of MS Excel. But when I select the the desired template, this error message appears. What shall I do here?
But I can export the excel data only in "File Export" window, not in the "MS Excel" window inside of the "Export".
Regards,
Vugar
can you check if the templates that are visible in Dewesoft are also visible in the Dewesoft system folder?
@Primoz Lapi Hi,
no they are not visible in there. What can I do there to bring those template files into that Dewesoft System file?
Dewesoft will create new templates if you delete the "Scripts" folder in Dewesoft system folder.
After the folder is deleted just restart Dewesoft.
Sorry, this will only create a folder without the content in it.
Attached are the scripts that you can copy manually.
hello,@Primoz Lapi, how to create a template by myself? what kind of tools do I need?
