Edit data header for dxd file
Is it possible to modify the data header section of a DXD file?
I want to add a field, for example, that I might have forgotten to create during the acquisition.
Thank you in advance for your feedback.
You can edit existing fields but it's not possible to add new ones.
To edit the existing fields, go to "Offline math":
And select "Data header". Here you can edit these values.
Fields are defined in the Project file. Since the .dxd file contains the Setup file (which includes these Project settings), you cannot add a new Setup to an existing .dxd data file. Therefore, it is important to choose the right Project to keep track of your fields. You can manage Projects in Options -> Project.
Additionally you can enable the option to always show the Data headers at the start of measurement to ensure all is there:
