DS IMU2 with RTK option and Dewesoft X2
Hi everyone,
Recently I have tried to run Dewesoft X2 for DS IMU2 with RTK option but the result is not as expected ( that mean it can not measure with the good resolution +/- 1 cm as specification of DS IMU2 with RTK option
- Horizontal position accuracy (RTK) : 0.008 m
So please advive me how to do ?
or do you have any Dewesoft X2 Instruction for DS IMU2 with RTK ?
Many Thanks
NCH
There could be multiple causes why the device doesn't achieve full RTK accuracy. For example it can be caused by problems in getting the RTK correction data, obstructions above the antenna, bad antenna connection...
For DS-IMU I would suggest that you download the DS-IMU manual:
https://www.dewesoft.com/download?file=DS-IMU_GYRO_manual_v1.0.0.pdf
We have one manual for RTK. It is not directly intended for use with DS-IMU2 but it has more information on RTK compared to the DS-IMU manual:
https://www.dewesoft.com/download?file=RTK%20Manual%20v1.0.2.pdf
Further discussion will be made by email, since you also contacted us there.
