Displaying arm light in a sequence
I am running a sequence test with X3 SP6 with the main tool bar off. Is there a way to show the arm light status on a measure screen, when I arm the test in the sequence.
Dear Mark,
do you have intentionally hidden the main tool bar? In other case you can help yourself with the Indicator lamp VC.
Regards
Eva,
Thank you for the reply. Yes we would like to have the main tool bar off, when running the sequence. I can add an indicator lamp on my measure screen, but can you tell me what input I need to use to show when the ARM lamp is on in the main tool bar.
Thanks
Dear Mark,
unfortunately, we can see that only "storing" event can be presented with the indicator lamp - in your case the "start trigger" and not the Arm lamp. Also there is not possible to create a math channel to track when the Arm button is pressed.
As we also think that this would be a good feature we will add it to the wish list and will inform you when there is an update on this request.
Regards
