DewesoftX 2021.3 Error Initiating Export Plugin On Startup
Hi
I recently updated to DewesoftX 2021.3 (also tried 2021.4 but doesn't work with CAN J1939) and each time I load the software I get an error message stating "Error initiating export plugin". I have re-installed the software twice now but no change.
Is there a resolution to this?
Thanks
Dear Oliver,
This issue is known for the 2021.3 version and has been fixed in 2021.4. So my suggestion is to migrate to 2021. but I wonder what kind of problem do you see with CAN?
Best regards
Dear Brandon,
I would start with deleting "ExtensionCache" folder within System folder. You can find System folder from here:
Then delete "Extensions" file
and run "DCOMreg.exe" that you find in Bin64 folder, after the registration is done run DewesoftX.
If this still won't help I would suggest moving half plugins out of "Addons" folder then run DewesoftX again, and continue the spliting cycle until you find which plugin causes problem. I can give you a hint that sometimes WFT plugin is not the proper one. You can delete it and replace it with the one on the Download center.
I hope this helps for you.
Hi all,
my solution to this problem (i ran into the same problem updating to 2021.3) is to remove the ASAM_MDF4 addon.
And running MonoDAQ-UX with DEWESoft 2021.4 or higher isn't working.
Best Regards,
Jasper
