Dewesoft X3 - Harmonic FFT resize
On Dewesoft X3 64-bit I am trying the adjust the axes on a Harmonic FFT control. I can adjust the x-axis by changing the maximum x value, however I am not able to adjust the scale on the y-axes. The cursor changes from pointer to text mode (as for the x-axis) however I am not able to change the limit value. I tested it on X2 and this worked fine then.
Thank you for informing us about this issue, I'll report this to our developers. While this is being resolved you can use the octave analysis math and the 2D graph for your measurement. I'll inform you when this is fixed.
I would like to inform you that the issue that you've reported in this thread has been fixed a while ago. If you download the current release version of the software (X3 SP3), you will be able to scale y axis.
@DEWESoft Support
Thanks! Will Dewesoft be releasing the binary files (for updating existing installations) for this release or is it only going to be the windows installers available?
No, we have decided that we won't upload binary files for official releases. Only RC and development versions will have binary files.
