Dewesoft excel reporting tool export error
  • Dewesoft excel reporting tool export error
Brandon Gross
Posted on 15.04.2019 22:03
I have Dewesoft file I am trying to make a template using the "Dewesoft excel reporting tool" and am getting an error message. After investigation it appears to be because of some XY reference lines I have on a XY recorder. When I remove these lines I am able to create the template without error. Is this a limitation of the Dewesoft reporting tool or am i doing something wrong? Looking in the reporting tool manual it may be a limitation. If so, is there any work around so that I can keep reference lines on my xy recording graph in Dewesoft?
Thanks,
Rok Kmetič
Posted on 16.04.2019 11:55
Dear Brandon,
we have simulated your configuration based on the picture providen, but unfortunately, we didn't detect any errors.
Could you please provide the data file so we can try to reproduce the issue on our site.
Regards.
Brandon Gross
Posted on 16.04.2019 13:32
Dear Brandon,
Regards.
Sure is there a secure place to upload?
Thanks,
Rok Kmetič
Posted on 16.04.2019 13:39
Please send the files to [email protected]
Regards.
Brandon Gross
Posted on 18.04.2019 15:11
So I believe I solved my problem. If you have the same file opened in Dewesoft that you are trying to create a template for using "Excel Reporting Tool' it errors out. Once I closed file down and tried exporting it worked without needing to delete ref lines.
I do have another issue now regarding "Excel Reporting Tool". Ill create a separate thread for this item.
