Dewesoft excel reporting tool cursor issues
I have several "crossing" Cursors made for a Dewesoft setup file. I also have calculations that incorporate the "crossing" cursors values. With "Excel Reporting Tool" I want to be able to pull this data into excel. Unfortunately it appears that none of these calculations run during export process and values come in blank? Am I doing something wrong? Is there a way to correct?
Thanks,
Dear Brandon,
can you please explain a bit more about the problem you are facing? You have a data file with cursor values and additional math channels which uses the cursor channels for calculation. You use the data file in "Excel Reporting Toll" and you get 0 for the channels?
As the Cursor math functionality is more for Analyze use, all the channels are in offline mode. And in this case the values of this channels can not be seen.
Which version of Excel are you using? Can you provide a data file which you are using?
Regards
