Dewesoft address claim
Brian Balvin
Posted on 29.06.2018 15:35
I am trying to set my Dewe43 as a specific address on a CAN network. I think I need to send the claim message as soon as the bus is powered up, is there a way to do this?
Can anyone provide an example on how to send an address claim message?
Primož Gorenšek
Posted on 03.07.2018 12:53
Dear Brian,
Is this for J1939? For receiving J1939 messages it is possible to set a source filter, like on the attached image. Is this what you meant?
Primoz
Brian Balvin
Posted on 05.07.2018 18:11
It is J1939. However, I am trying to transmit a set of messages as coming from a specific node. I need other controllers on the bus to see my Dewe43 as "D5"
Primož Gorenšek
Posted on 10.07.2018 14:57
J1939 in this way can only be send as a standard CAN message. There you would have to define the Arb. ID and complete message and you would have to know exactly which bits represent the address. It is a bit of work but possible if you know how exactly the message should be constructed. With math, you could also make a formula to increase the address value if the one sent is already in use.
Brian Balvin
Posted on 10.07.2018 15:31
I figured it out. If I uncheck the J1939 checkbox, I am able to enter the full address. Unfortunately to uncheck it, I had to delete all the channels that were set up and redo them. But it is working now.
