Dewe43 Ground Connection
A Sam
Posted on 10.05.2018 20:59
Hi there,
Just wondering, how important is it to connect the GND terminal on the Dewe43 when conducting a vibration survey with two triaxial accelerometers that are mounted with ground isolation. I also bring in a proximity sensor 0-10V voltage signal into the same Dewe, not sure if this matters to your answer.
Thank you,
Sam
Shaun Maconaghy
Posted on 17.05.2018 22:16
I have had grounding troubles several times using Sirius and Minitaur slices. Once a machine would not start because the Minitaur was causing voltage issues on the CAN bus. After I grounded the Minitaur to the machines battery the problem went away. I suggest grounding every time. Hope this helps!
signup
for
free
account
