Device locked - unlocking FAIL - SeedKeyCal6.dll error (126)
We are trying to configure XCP master on dewesoft to handle XCP signals. However, we get a 'Device locked - unlocking FAIL - SeedKeyCal6.dll error (126): The specified module cannot be found' error. Can you help us with this issue? Is it possible to configure SeedKey somehow through Dewesoft? Thanks!
@Chandrasekhar Nagaraj
Hello!
Regarding this error I suggest:
- First, check if you have SeedKeyCal6.dll file in Addons64 folder of DewesoftX.
- Second, if you have 32-bit DewesoftX and you might have 64-bit .dll file or vice versa (Dewesoft won't find it)
Regards,
Jernej Moljk
@Jernej Moljk
Hello!
Thanks for your response! We added the 'SeedKeyCal6.dll' file to the Addons64 folder as you suggested. However, we get the following error now 'SeedKeyCal6.dll error (193): is not a valid win32 application'. We have checked that DewesoftX is 64-bit. How should we proceed here? What do you think is causing the issue - could it be that the .dll file we have is 32 bit?
Regards,
Chandra
Hello!
Sorry for my late response.
You might want to open your .dll file with notepad and then check if it contains in the first part of the file:
- if .dll file is 32-bit, it contains: PE L
- if .dll file is 64-bit, it contains: PE d†
Regards,
Jernej Moljk
