Deactivate or activate individual cursor for diffrent displays?
  • Deactivate or activate individual cursor for diffrent displays?
Stefan Lange
Posted on 14.10.2020 11:07
Hello, it is possible to deactivate or activate individual cursors for different displays or recorder?
an example:
I don't need the cursor "P_Load50% _off" here
Posted on 14.10.2020 16:14
Dear Stefan,
you can for example hide all the cursors for the current widget, but unfortunately, you can not choose which cursor will be hidden.
To hide the cursors you need to uncheck the "Show time cursor channels" in the Drawing options for the Recorder widget.
Regards,
Stefan Lange
Posted on 15.10.2020 09:27
Dear Eva,
or you can set the "cursor search mode" to "manual" and "timestamp" outside the zoom window.
But this is quite complex when evaluating long term tests with different operating points.
Selecting the cursor for a recorder would be a relief.
Regards
Posted on 16.10.2020 09:48
Dear Stefan,
we totally agree and we are already working on updating the markers for the recorder widget in the future. The markers are already in the development but we do not have a defined timeline for this feature.
Regards
Frank Albertson
Posted on 26.10.2020 08:49
You can hide all the cursors for the current widget. Simply uncheck the "Show time cursor channels" in the Drawing options.
2048
Stefan Lange
Posted on 26.10.2020 11:18
Hello, Frank,
yes I know.
Eva has already mentioned it.
But I want to disable a certain cursor for a recorder and not all of them.
regards Stefan
fura joy
Posted on 27.10.2020 05:41
Step by step:
Some data analysis software tools or methodologies requiere that data is exported to different sampling rates compared to the ones it was stored with. This can be achieved by resampling and then exporting data to the desired custom rate.
DS_exporting_resampler_types
You can choose between three resampler types:
  • Hold
  • Linear
  • Alias free
Hold
The easiest and most straightforward resampling method is the Hold method. It outputs the last sampled value until the next one becomes available. This method can be used to export data from Scalar, Vector or Matrix channels. Their time base can be Synchronous (samples are uniformly spaced) or Asynchronous (samples are nonuniformly spaced).
For a timestamp of 2 s, the value of a selected sample is exported, if we want to export the green signal with an adjusted export rate of 1 Hz.
Linear
A method that is a bit more complex and accurate method is linear interpolation. It calculates new samples by performing a linear interpolation between two samples. This method can only be used to export data from Synchronous or Asynchronous Scalar channels.
For a timestamp of 2 s, the interpolated value is exported, if fwe want to export the green signal with an adjusted export rate of 1 Hz.
Alias-free
The most complex method and the one which produces the most accurate results is the Alias-free method. It resamples the data by filtering it with an anti-aliasing filter. The properties of the filter used can be set in the Options -> Settings -> Advanced -> Export -> happy wheels. This method can only be used to export data from Synchronous Scalar channels.
Export rate
The export rate of the exported data is not completely custom. Because of the way the data is written to different file types we distinguish two ways of exporting data:
  • Channel-based, where every channel is its own entity and a custom export rate must be a multiplier of the acquisition rate.
  • Value-based, where the custom export rate must be a multiplier of all the channels’ sample rates.
The export types of all the available file types can be seen in the table below.
Channel basedValue basedFlexPro [*.fpd]Microsoft Excel [*.xls]Matlab [*.mat]DIAdem [*.dat]UNV 58 [*.unv]Text File [*.txt/csv]FAMOS [*.dat]Sony [*.log]NSoft time series [*.dac/mdf]RPCIII [*.rsp]Technical data management [*.tdm]Comtrade [*.cfg]JSON [*.json]Replay [*.rpl]ASAM MDF4 [*.mf4]BWF [*.dat]S3 [*.s3t]HDF5 [*.h5]DynaWorks neutral file [*.nt]Standard data file (SDF) [*.dat/sdf]WFT [*.wft]Wave [*.wav]Google earth [*.kml]CAN messages [*.csv]IFile [*.csv]
The maximum allowed custom export rate of any channel in a data file is the sample rate with which the file was stored (overall dynamic acquisition rate).
Channels of some data structure (String data, Binary data…) cannot be exported using the methods mentioned here.
