"cursor beyond eof" error when opening data multifile
  • "cursor beyond eof" error when opening data multifile
Aleš Faifr
Posted on 28.05.2025 13:21
i would ask to, when i opening data multifile a got a warning message "cursor beyond eof", how to solve this issue?
I using newer version of dewesoftx and i am unable to open mutifile, only solution is exclude files with this message from multifile before opening.
These files are able to open separately, but i dont understand why this issue happen and how to avoid in future.
Thank you for the answer,
Aleš Faifr
Rok Kmetič
Posted on 30.05.2025 08:49
Dear Aleš,
This happens when data recording is unexpectedly stopped (the file is not closed).
Either something crashed (could be any part, from plugins, core, devices, widgets,...), which should be in most cases, visible inside the error log, or Dewesoft was suddenly closed in another way (kill the process, computer power loss, Windows blue screen...)
You can try fixing this issue by opening the data file, move the yellow cursor and then save. If the issue is still present you can share the file with us and we will try to fix it.
Best Regards.
Rok
Aleš Faifr
Posted on 05.06.2025 09:52
thank you a lot, now its working and i am also able to repair multifile to full working state.
Aleš
