"Crossing" Cursor displaying incorrect values?
After watching this video (https://www.youtube.com/watch?v=GCq4utEmlKU) it seems that the "crossing" cursor is supposed to interpolate to give you numbers between captured data points. But, I have found some dependencies with this. I have a file with a "crossing" cursor (Dynamic Range Minimum/Torque) set to a level of "113 Nm". When running formulas I do not get Dynamic Range Minimum/Torque values at 113 Nm on the "Digital Meter" or on my "XY graph". See picture explanation below. This seems to be an error?
Thanks,
Dear Brandon,
yes, you are correct. When using the "crossing" functionality you get the result of both channels when the selected channel in the settings crosses the entered value in the setting. Would it be possible that you provide the data file so we can look into this issue?
Regards
