Cmd failed to start (error code: 267)
in 'simulation mode' compiler give me error code 267)
"Cmd failed to start (error code: 267)
Compiling... success."
with A43 connected, the module even not starting (pic in
attachment)
Can you give some clue where I should look the reason?
Dewesoft X3
Version: SP7 (RELEASE-190607)
Build: Release
Copyright © 2000 - 2019 Dewesoft. All rights reserved.
Product licence: PROF (Professional)
with "DSMinGW" downloaded from Dewe WWW
Thank you
Michal Nawrocki
Dear Michael,
we apologise for the late response on this topic.
The attached error pops out because the c++ script math requires a license and the professional Build in license is not enough.
Can you please check the path of the DS-MinGw program in the registry editor? You need to look into the following path:
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Dewesoft
The program should have the path as it is on the attached picture
Regards
thank you.
1) License
yes, I recognized the root of my problem.... -> changing the C++ from "free" to the "Licensed" tool.
Somehow I missed the info about that. .... in same time problems with WIN, fresh system.... long story :-)
2)DS-MinGw
Registry is ok.
Probably all errors will gone after start the "commercial" C++
thanks
MN
Dear Michael,
yes the license has been changed and on the following link you can find all information about the licensing for the C++ script.
If you will have any other questions about the script, feel free to contact us.
Regards
When using 32-bit Dewesoft with 64-bit Windows OS the path for the DSMinGw program in the registry is different:
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\DEWESoft
Regards
