Clarity regarding the motor analysis tool.
  • Clarity regarding the motor analysis tool.
Ambareesh Veeraraghavan
Posted on 25.07.2024 05:15
we are using dewesoftx to visualize the dq axis current of 3 phase pmsm drive using the motor analysis tool. the obtained dq current mimic the motor phase current and vary sinusoidally we expect it to be a dc term. we are using sin cos encoder and interfaced it to the motor analysis setup, how is the angle alignment done. we tried the align to d axis function while the motor is running and it gave different value everytime.
Thank you
Pika Kreča Šmid
Posted on 27.09.2024 06:12
Dear Ambareesh,
We would firstly like to apologise for reaching out to you so late via the forum- we did notice that one of our agents reached out to you on a ticket, but it looks like the answer has not reached you.
From your description, I gather that you are working with our Power analysis module, specifically the Motor Analysis section, and are using a sine/cosine encoder to measure the angle.
Unfortunately, we cannot cannot give you a definite advice on how to proceed, as we do not have enough information about your current setup.
We would kindly ask if you could send us the datafile, so that we can see exactly what's going on, and so that we can give you the correct advice.
You can use our private forum to upload the files. Here are the necessary steps:
  1. Login to our website
  2. Use your current account, create a new one or use a Google sign-in.
  3. Open Forum discussions section
  4. Go to Support tab and click on the Forum discussion section.
  5. Private support discussions
  6. At the bottom of the page, there is a private forum section, where you can create your own private topic.
  7. Create a new topic
  8. Add a title, add an email of a person you want to inform to the description.
  9. You can also or copy a link of the topic and send it to Dewesoft Team over an email. In the second field, you can also add a detailed description of a problem or files. Then attach the files you would like to share with the Dewesoft Team. In the form you have described which format of files are supported to upload here.
Please do note that all files together shouldn't exceed 50 GB.
Pika
