Changing Setup on a roving hammer test
Hi
I have a triggered roving hammer data file with 1 acceleration channel and 59 hammer excitation channels. When I go to setup and change anything on the modal test page the acceleration only appears to be retained on the first hammer excitation and all other results are lost. Even changing the number of lines causes this to happen. This does not happen with my multi acceleration response and one hammer excitation data files which recalculate with any changes.
I would like to review and present the results in terms of mobility (mm/s/N) and be able to change the number of lines.
I have some files where a change has been made and saved. Is there a way to restore the results?
Software Test Engineer I
I believe you have a similar question as Ben McMahon in his thread, so I would like to direct you to there, where I hope you will find your answer: https://www.dewesoft.com/forum/posts/537
Like I said in that thread; unfortunately the triggered roving hammer method doesn't work in offline (analysis) mode. If you have any more questions feel free to ask.
sorry I forgot to mention you should be able to restore your files with the "Revert to original" option in DEWESoft.
