Change value of a variable in ramp
  • Change value of a variable in ramp
Dino Morio
Posted on 17.03.2021 16:04
Hi, I have a case where the user defines the set point of a variable. However, i would like the value to ramp to that setpoint at a ramp rate (again user defined) rather than a step change. Is this possible in Dewesoft x software?
Primoz Lapi
Posted on 18.03.2021 10:49
would it be possible to get some more information about the application?
We are not sure where you have these variables.
Primož
Dino Morio
Posted on 18.03.2021 13:05
Many thanks for the quick response.
Basically, I have 3 variables Speed_SP, Speed_Control and Speed_Ramp_rate. I would like the value of Speed_Control to ramp from "a value" to "Speed_SP" based on the user defined Speed_SP and Speed_Ramp_rate.
Primoz Lapi
Posted on 22.03.2021 11:12
attached is a setup file with a workaround for you. There is no direct way of doing this but it can be done with a formula.
This formula will check the previous value and then add or subtract the value depending on the current value of user input.
Primož
Dino Morio
Posted on 22.03.2021 14:21
Thanks Primož
Seems like it does what I want...Will test it further.
Is it not possible to add this as a standard feature in to the "Math" tool box?
