Change imported CAN message to be transmitting
  • Change imported CAN message to be transmitting
simon ögaard
Posted on 29.05.2024 11:30
Hello! Is there an easy way to change imported CAN messages from receiving to transmitting? I have hundreds of CAN messages in a DBC file, and every time I load them, they default to receiving. I need them to be set to transmitting, but the only method I've found is to recreate each message from scratch in Dewesoft every time I close or change the setup. This process is quite tedious with so many messages and since I also close Dewesoft or change the setup and loose all the messages all the time. Any suggestions?
Gregor Šmit
Posted on 29.05.2024 12:41
Dear Simon,
you can select all the messages, right click and select Copy, and then right click and select Paste (swap Rx/Tx) option (hint on page 7 of the manual):
simon ögaard
Posted on 29.05.2024 13:15
@Gregor Šmit Thank you!
Miss Sophie
Posted on 12.11.2024 09:30
@Gregor Šmit Thanks for the information you shared, tiny fishing was easy to understand and helped me fix the problem quickly and conveniently.
