CAN transmit source address
I am trying to transmit a J1939 CAN message that another controller is expecting from a specific source address. I have the info below, but and having trouble setting up the message. My Dewe 43 is acting in place of the ECU.
ECU Address = D5
Dual Channel Processor (DCP) address = 9F
Message Description: Weight
PGN: 61184 (00EF00)
PDU specific = Destination Address
Data length: 8 bytes
Default Priority: 7 (lowest)
Direction: ECU=>DCP
Repetition rate: per drop
Description of each byte of the Weight Message
Bytes Bits Parameter
1 8-1 Message type LSB (0xFF)
2 8-1 Message type MSB (0x00)
3 8-1 Weight LSB
4 8-1 Weight
5 8-1 Weight MSB
6 8-1 NA
7 8-1 NA
8 8-1 Weight units (1= 0.1 kilograms)
How do I set my transmitted message to the ECU source address, or set the Dewe 43 as this address?
The arbitrary ID field only allows 4 digits, yet as I understand my message ID for this should be 7EF9FD5.
In this case I have other messages that I also need to send, also with the same PGN, destination address, source address, and sometimes the same priority level. What am I missing to differentiate between messages?
