CAN plugin speed and function
I would like to ask you what happened with your CAN plugin, because the working with this plugin is pretty uncomfortable. The speed of this plugin is pretty poor and when I want to make all channels as saved, DEWESoft stuck, freeze and after 45 minutes is still freeze. In previous version of DEWESoft it was not much faster, but after 5 mins it works again and all channels were active and stored. I tried it for more times, but I have been giving the same result - freeze Dewe and impossibility to make a measurement with wanted setups. The CAN is under Volkswagen group company.
Could you, please, double check this plugin and its speed?
Thank you in advance for any information about fixing problem.
Regards,
Jan
Dear Jan,
thank you for reaching out to us. It is sad to hear that you have issue while using the CAN module. Would you please be so kind and provide some additional information:
- number of CAN channels
- DewesoftX version
- data file or setup file
- are there any issues while storing the data or just in setup
Kind regards.
Hello Gregor,
thank you for your reply. In previous it was not so fast when I had to save all CAN messages/signals, but it worked. But with new version of Dewesoft (2023.2 (RC-230118)) I am unable to check all channels/signals as stored. Few signals are without problem, but when I want to store whole CAN it freeze down and after more than 45 minutes it is still freeze. In past it takes approx. 5 minutes to unstuck. Luckily In 99.9% of usage is not necessary to storage all CAN and I am working with only up to 10 signals.
And to your question:
- I am using only one CAN input (especially Antrieb CAN database file - Drive CAN of VW cars)
- version of Dewe is mentioned above
- it does not depend if it is current setup or blank new only with CAN
- this issue is only in setup before starting measurement (which can't be start, because Dewe freeze without any response)
Thank you for your time with helping me :)
Regards,
Jan
Dear Jan,
thank you for the additional information. I have reported this issue to our developers and will keep you updated.
Kind regards.
