Camera recording latency issue
In my recording experiments with the webcam, I found that there is a 400ms delay between the camera and the signals. I tried to use the Post-Sync Video function to tolerate this delay, but it did not work. Unfortunately, the duration and timing of the videos I created with the Post-Sync Video function do not match the signals.
Is there a solution for this?
@Mehmet Aksoy
Hello everyone, I found the cause of this problem. The problem was that the camera frame rate performance was 15 while I was trying to record with 30.
The question, is it possible apply post-sync video for multiple test records at the same time with same offset with batch or something else.
Dear Mehmet,
Thank you for letting us know about the solution.
Regarding "apply post-sync video for multiple test records at the same time"
- Do you have a lot of datafiles each with corresponding video file that you would like to adjust the delay*
- Do you have one datafile with multiple video recordings that you would like to post sync with single datafile?
