BUG: develop plugin for dw7.0 & 7.1
lv
Posted on 17.01.2014 15:43
These codes developped by C++ Builder 2010, It's trying to edit the channel name, unit, scale and offset.Code 1 and 2 works well. But, something wrong with code 3 and 4.The channel name cannot show the full string For example, if text of Edit5 is "Edit5", then the channel name can only show as "Ed".The channel unit will show no change , still the same as before. But, very strangely, int the list view of all channels, the physical values column, will show part of the new unit string. For example, if text of Edit4 is "MPa", then it will show "M".
It should be bugs.
1 curChannel->set_Scale(Edit2->Text.ToDouble());
2 curChannel->set_Offset(Edit3->Text.ToDouble());
3 curChannel->Unit_=Edit4->Text.c_str();
4 curChannel->Name =Edit5->Text.c_str();
It should be bugs.
Marjan Grilj
Posted on 20.01.2014 09:35
Suggested is to check that strings passed to unit and name properties are in UTF16 format.
lv
Posted on 21.01.2014 15:58
thanks for the anser.
the problem is fixed partially using the following codes. Channel name can be modified correctly.
But the unit property still have the problem. Shown as the picture.
In the all channels list view, the unit seems to be changed as red circle marked in figure 1.
But once the channel property window opened as shown in figure 2, the unit seems to be not changed marked as red circle.
Possible be a bug?
curChannel->Unit_ = System::WideString(Edit4->Text.c_str()).c_bstr();
curChannel->Name = System::WideString(Edit5->Text.c_str()).c_bstr();
Marjan Grilj
signup
for
free
account
