Beat Frequency IEPE ACC
Sepi Sund
Posted on 24.03.2021 08:19
Hello :),
We have some troubles on Krypton One ACC and ACC DSI, the case :
  • We generate a sin periodic signal (with an IEPE simulator) on our Krypton One ACC (IEPE mode) : 4V peak to peak , 5kHz. The sample rate of our Krypton One ACC is set to the maximum 50kHz. So Shannon criteria is OK.
  • The problem is that in measurement mode we observe a signal : 3.7Vpp to 5kHz, with a beat frequency, the signal (peak to peak) is not stable in time, the higher the frequency signal is the higher the beat frequency is.
  • With an oscilloscope, no problem, we have 4Vpp.
Do you think the beat comes from the AAF filter ? Or an other soft/hard filter that we can't see ?
We observe the same on a Sirius 8xSTG with DSI ACC.
Best regards :)
Matic Pevec
Posted on 30.03.2021 11:03
Dear Sepi,
Can you send us the datafile that has measured the phenomenon? I would like to discuss it with my colleague and find a solution for you. You can either use support@dewesoft.com or create a Private forum session to send datafile to us.
BR
