Average value calculation at any given time or between two events
  • Average value calculation at any given time or between two events
Nataraj Jyoti
Posted on 25.02.2019 16:21
I want to calculate average value of measured signal with below condition
  1. the last 5min of measured signal
  2. between two events in the total measured time Or between two time stamp in the log
please find the attached image for the referance
Posted on 26.02.2019 08:24
Dear Nataraj,
for the calculation of average value of the signal between two time stamps or events you can use Basic statistic with "Start-stop block" option.
For calculation the average value of the last 5 minutes of measurement we suggest the offline calculation. You can create a single value channel in Math with only acqtime for "Stop time" channel. For "Start time" channel you can only divide the 5 min from the stop channel. You can then use the channels as trigger channels in the basic statistic with "Start-stop blocks" option.
Regards
Nataraj Jyoti
Posted on 26.02.2019 10:17
Thanks for your support but I failed to create triggers to use start and stop blocks. I have attached signal file, could you please help me to understand both way of measuring average values in the attached file.
Regards
Nataraj
Posted on 26.02.2019 14:53
Dear Nataraj,
attached is a data flle.
Regards
Nataraj Jyoti
Posted on 27.02.2019 08:09
Your attchment dosn't contain right file format in order to open in DEWESoft, could you please check?
I have attached snapshot for your reference.
Posted on 27.02.2019 08:16
Dear Natraj,
you just need to change the *.zip to *.dxz and than you can open the file.
Regards
Nataraj Jyoti
Posted on 27.02.2019 09:35
I did try but not succeed, could you please share me a same file in .dxz format?
Thanks in advance.
Posted on 27.02.2019 11:23
Dear Natraj,
unfortunately, every *.dxz file will be transformed into *.zip file. Please see attached pictures.
Regards
Posted on 27.02.2019 13:58
Dear Natraj,
our developers have fixed the problem with the changing format. You can find the *.dxz file attached.
Regards
