Automation Using Matlab
Axel Bomhauer-Beins
Posted on 23.11.2011 13:20
Dear all,
I would like to use the DEWE-5000 oscilloscope for automatic testing. That means that the oscilloscope shall be fully remote controlled by MATLAB running on another computer.
Until now, I was able to estlablish a connection to DEWETRON using following MATLAB sequence:
ACTX = actxserver('Dewesoft.App', 'machine', '10.0.1.79');
ACTX.Init;
ACTX.Enabled = 1;
ACTX.Visible = 1;
ACTX.Top = 100;
ACTX.Left = 100;
ACTX.Width = 1024;
ACTX.Height = 768;
ACTX.SetInstrument(1);
ACTX.ShowStyle = 2;
Performing this sequence, I succeeded in starting up DEWEsoft at DEWE-5000; a sequence to quit I found as well.
Now I am trying to perform very basic actions like scaling time- and y-axis, setting an auto-trigger etc. using the ACTX handler in MATLAB.
Unfortunately, I did not find any working command in order to do this. Especially I am irritated that the command ACTX.SetScopeParams(0, 0, IChannel, 0) - where IChannel = ACTX.Data.Used.Item(0); and AI0 has a sin at the input - as documented in the DCOM reference on pgs. 62 and 121 gives the error "??? No method 'SetScopeParams' with matching signature found for class 'COM.Dewesoft_App'."
I now wonder: Is it actually possible to fully remote control the DEWE-5000 via MATLAB? And if yes: Where can I find a more detailed manual on the commands and their way of use?
I would be very grateful for any constructive answer.
Axel
Dewesoft Developer
Posted on 24.11.2011 10:32
Dear Axel,
I have crated a demo file for you how this should work. Also I have a few questions and I can see a mistake in your code.
Can you please contact us on the support mail (support@dewesoft.org), so we can send you test files and help you with the other issues.
Tilen.
signup
for
free
account
