Automatic Events
I would like to have a new event (and associated timestamp) created when a widget lamp is on (which in turn, lights when it sees a voltage > 2V on the assigned channel). How would I do that? Otherwise could I export the lamp status (0 or 1) along with the recorded channels? Thanks in advance,
Francesco
You can use the alarm function to achieve the first option, you just need to setup the trigger and click the add event button. For second exporting the 0 or 1 will happen automatically, but you can control what gets output with the channels tab, export options might be hidden by default so you might have to right click on header row to see all the options.
@Gary Floyd Are triggers only available with "fast on trigger" and "fast on trigger, slow otherwise" options? What if I want to record "always fast" and still setup triggers I can then reference on post production? Thanks
to add the event on condition, you can use alarms. For the alarm start conditions, use the same condition as is used for light and make sure "Add event on alarm" is enabled.
