Auto coloring the channels
hi All-
i am using DEWESoft with 500channels daily and it is EXTREMELY difficult to color each channel on each setup!!
is there an automatic way to color the channels so i dont have to do it one-by-one?
for example: using a color gradient on the entire filter chain and DEWESOFT goes from deep to light automatically?
really appreciate if someone has a good way to do it. thanks
thanks for the instructions, i ACTUALLY MEANT how to DO IT automatically? when i added new channels they all come with the same color and i dont have the time to do it one-by-one, i already knew about how to disable it but i would liek this to be done automatcally? sorry if i am not clear on my question it is hard to describe exactly!
there is no way to do it automatically. If you apply the steps shown in the previous reply when the setup is finished, you can change color of all channels simultaneously.
@Primoz Lapi Thank you for showing this. This setting has moved from the global/project settings in the last 1-2 years, right? Regardless, my issue has been solved now!
The feature is the same over the years. Do you refer to some other functionality?
