accessing .d7z file format
I got a .d7z file. Could anyone please help me in opening that. I tries DWDatareader. But it is now working with it. Even in the documentation of DWDataReader, nothing is mentioned regarding .d7z file. Kindly provide your views.
Thanks,
Harish
Dear Harish,
the DwDataReader should be able to read the *.d7z files. Can we ask you which version of DwDataReader do you use and which programming language are you using?
Also if possible, could you share the data file with us so we can check? You can also share the data file to the private forum or our FTP server.
Regards
@Eva Kalšek
Hi Eva,
Thank you for the quick reply. I was initially using a python module named pyDewesoft. It was reporting memory allocation error. After seeing your mail, I just downloaded the DWDataReader from Developers section to check and it worked.
Thank you.
Regards
Harish
