about keyboard events during recording...
  • about keyboard events during recording...
Rick Emerling
Posted on 09.09.2016 14:10
Tech support wrote: If you don't want to have keyboard events in your data file, you can change the key that activates them while recording, so that you won't accidentally store them.
It's unclear what you meant when you said "you can change the key that activates them while recording". Can you provide more info on that? Thanks
Posted on 09.09.2016 15:52
keyboard events are activated when you press the space bar by default. I simply suggested that if you might be pressing the space bar by accident, you can change the shortcut for keyboard events in DEWESoft's settings. This can only help you with new measurements and you cannot remove events from an already recorded data file. There is a picture of where you can edit your shortcuts in the previous topic. I hope this clears things up.
Fabian Schnurre
Posted on 02.12.2024 14:38
Hello Support, is there a way to use keyboard events during recording in sequencer? I've tried it but couldn't see the events in the analyze mode later in the sequence
Rok Kmetič
Posted on 04.12.2024 12:25
Dear Fabian,
I have made a simple sequence and tested the keyboard events by pressing the space button. I can confirm that the keyboard events during recording in the sequencer work well.
Please see the attached video of the test.
Best Regards.
Fabian Schnurre
Posted on 04.12.2024 13:58
Hello dear Rok, thank you for the Video. I can confirm this, yes. Here is my sequence, where in the end I go to Analyze mode to review the data. This is where keyboard events and other don't show up:
I did just realize though, that if I have a recorder widget in the display like you have in your video, that it will show the events. Thank you!
Rok Kmetič
Posted on 04.12.2024 14:22
Dear Fabian,
here is a useful tip:
If you enable the ''Show main toolbar'' option you will be able to see the keyboard events later in the analysis.
Fabian Schnurre
Posted on 04.12.2024 15:24
Thanks Rok, is there an action block for sequencer that enables or disables show main toolbar?
Matic Pevec
Posted on 05.12.2024 10:21
Dear Fabian,
No sequencer command can disable or enable "ShowMainToolbar".
If you want to have it hidden but navigating through, you can use "SetMainToolbar" action block.
For example if you want to enable "Design mode" you will do like this.
Which will click to "Measure" and then enable "Design".
